An attempt was made to remove a list of ports from a VLAN, but the operation did not succeed.
The CLI command "show vlan fabric attach assignments" will display VLAN and NSI values known to Fabric Attach for each port . Output from the "show vlan <vlan>" command will include a list of ports that have been added to that VLAN. From these, it is possible to determine which port(s) did not get removed, though unless the VLAN manager logs a message, there is no way to tell why the failure occurred.
Warning
Failed to remove %numPorts% ports from VLAN %vlanTag%
| Name | Type |
| vlanTag | VLAN-tag |
| numPorts | uInt |
